Which headers
This is my current combo and I need to buy new headers.This car also runs on Alky.What size tubes and would this benefit from step headers?
383 sbc,hooker super comp 1 3/4 #2131 headers,comp .558 550,260,266 at .050,108 on 104 icl,14-1,dart iron eagle 215 platinums ported,2.05 1.6 valves bowl blended and port matched to a 2925 super victory,alky 810 carb,power glide,4.56 gears,4800 convertor,3100 lb car.This is a 1/4 drag car.Here are the flow numbers: http://i144.photobucket.com/albums/r...33/Image37.jpg |
I would suggest 1 7/8" Hooker super comps., they come with stahl adaptorplates (7 bolt conversion) that is what i have on my 377" on alcohol and i also ran them on the 406" before i broke a rod bolt. They work well and are inside the frame on my Malibu, but i did have to install turn outs to keep the fumes out of the car.
JMO Zip. |
JMO Zip. -for sure not over 2" |
Here is why I'm asking.......The exhaust port on my head is .080 wider then the width on the header on all exhaust ports.My question do you think this is hurting performance?This car has run 10.14@131
JMO Zip. |
That's a fact Jack ! Not only are you pushing through a physically smaller opening but you also add in the 'laminar' layer (although infinitesimal) and the opening gets even smaller. ANY 'edge' will be a larger restriction than it 'looks'. Blending with a shallow taper can reduce that significantly. as per a venturi.
| All times are GMT -8. The time now is 01:48 AM. |
