-   -   Rewiring Brake Light (https://www.racingjunk.com/forums/showthread.php?t=32287)
jreiley 07-06-2012 06:51 AM
I'm in the process of rewiring a race car (85 camaro) that had the worst case of wire bloat I've seen. I need to wire in a brake light. It wasn't wired for one before. Is it as simple as attaching a switch that gets activated by depressing the brake pedal and running a wire to the tail lights?
fast75vega 07-06-2012 11:55 AM
Re: Rewiring Brake Light
yes it is but remember that the switch is just a contact point on the hot side :wink:
TheYellaBrick 07-06-2012 01:05 PM
Don't forget to fuse it BEFORE the switch..........
oldandtired 07-07-2012 06:46 AM
There is a neat little pressure activated switch that plumbs into your brake line available for $10.00.
jreiley 07-07-2012 07:35 AM
So what is the switch called and where can I get it? Thanks.
fla1976 07-07-2012 08:04 AM
Painless Wiring 80174 - Painless Performance Low Pressure Brake Light Switches
TheYellaBrick 07-07-2012 12:06 PM
Or a stock switch that works off the pedal;
http://www.rickscamaros.com/electric...did=9873793231
bcw49 07-07-2012 03:14 PM
Here's a picture of a pressure switch for a 62 Ford Galaxy.
http://www.rockauto.com/catalog/moreinfo.php?pk=1185671
jreiley 07-08-2012 11:58 AM
Am I right is assuming a T fitting is put in the brake line coming off the master cylinder? Do I feed it 12v and the pressure switch lets the 12v go out the other wire?
oldandtired 07-09-2012 10:01 AM
I use the high pressure switch off a T in the brake line . You can wire it both ways:
Power thru the switch to the tail lights to ground.
or
Power thru the tail light to the switch to ground.
Of course as DD said, "fuse it..."
Speedway # 910-31305 identical to the Painless part.
