-   -   Trans swap ... Help (https://www.racingjunk.com/forums/showthread.php?t=32267)
shaybliss71 06-27-2012 09:17 PM
Trans swap ... Help
Ok Guys, Im looking at buying a street 1969 camaro. It has a powerglide with BBC in it now. I would like to know what all is involved to convert it over to a 5 speed or 6 speed manual. Any cost estimates would be helpful too. I am not sold on any one type of trans. Engine will make about 650hp. It wont be a daily driver but driven often. Suggestions, and whats involved would be great. Thanks.
oldandtired 06-28-2012 12:16 PM
First, you have to pick your transmission, keeping in mind that BBC will make some torque.
With a Richmond or Tremec TKO you can use standard Chevy scattershield and mechanical linkage.
If you a B/W T-56 from a 93 to 97 Camaro/Firebird, you can get an adapter scattershiled and use the "pull style linkage".
If you get one from a 98 to 01 Camaro/Firebird, it uses a different adapter bellhousing.
Good luck!!
TheYellaBrick 06-28-2012 03:27 PM
Wasn't it 'Bone or one of the guys here who did a similar swap a year or two ago ?
