Drag car shocks
Hi, I have a 74 Vega Tube chassis Drag car, It has Strange coil over adjustable Shocks all the way around. The front seems to sit low, Has a Glass nose & the tires seem to Rub when the wheel is turned. I havent had it out yet, It might be ok, Just wanted to know if There was a way to lift it up, There is more adjustment on the coils to go up. 383 Stroker motor . Thanks
I think you answered your own question. If after adjusting the coil overs and it still rubs, it's break out the die grinder time. Of course, without actually seeing it there may be other solutions as well, so pics would help us help you find a solution. |
| All times are GMT -8. The time now is 10:15 AM. |
