dragster alighment
I need the correct castor, camber and toe in specs for a rear engine hardtail dragster.
Thanks, Mike |
I'm not sure what the newer cars are running for castor, but camber is usually at 0 and toe is around 3/16". I'm dead on 3/16" toe static and it's 0 running down track. I'm also at 55* of castor, but I have an older dragster with the solid front axle instead of the newer tripod setups. I'm at 0 camber as well.........
| All times are GMT -8. The time now is 08:03 PM. |
