procomp heads
Are procomp heads known for premature valve guide ware 1500 miles should I fix or just get different heads :roll:
ive seen alot of people posting on different sites about this problem and the pics i seen look bad too. must have 3000 miles or less on them
everyone i talk to that runs procomp likes them and haven't had a problem yet but see if they will fix them id contact pro comp
Don't know if PBM Strike Force heads are the same as Pro Comp. But they're Chinese and the valve guide ended up being very badly worn in two thousand miles. I got rid of them and got a set of Dart Pro 1's. With out changing anything else, I went from 457 HP to 485 HP.
There is quanity of air Then there is quality of air!!! |
| All times are GMT -8. The time now is 06:06 PM. |
