-   -   switching to alcohol (https://www.racingjunk.com/forums/showthread.php?t=32084)
burmie1932 05-06-2012 04:02 PM
Do you still run the foam in the fuel cell and can I run the return to the other bung on the bottom of the cell?
bbchevy 05-06-2012 04:30 PM
Re: switching to alcohol
No,and NO!
Later
G 8)
rosameelpito 05-10-2012 07:19 PM
no foam on cell , return has to be on top of fuel cell, alcohol doesnt like alot of timing , probably 28-33 degrees on a bbc depending on motor, start with a fat tune , and go down form there , its safer you may milk oil a little but its better than blowing it ...
SPEEDNEEDS1 05-10-2012 10:31 PM
I am running my first alky set-up this year, my only advice is go with a well known carb. builder "APD, Rupert" being the best in my opinion. Mine is a APD, I took it out of the box, bolted it on and never even adjusted the idle. After I fixed my car issues, it is DEADLY AND I RUN 4 RACES BEFORE OIL CHANGE, just cause I felt guilty. It still looked like new.
APD 419-855-3073 JOHN KYLE
JimmySmith 05-12-2012 05:12 AM
NO & NO Later J.Smith 4621 racing
burmie1932 05-15-2012 05:30 PM
thanks for the help. I will be running a Ron's Toilet on a bb chev
