sbc 383 stroker
hey,i got an sbc 350 and i wanna make it in to an 383 stroker that makes about 400 to 450hp i have an highrise intake,202 camel hump heads, and im looking at an hydraulic roller cam,and seed pro pistons to get the cmpression up to about 10:1. what do yall think, thanks guys
How radical do you want it to be? What intake do you have?
You want to race or just sound good or both? It's an all N/A build right? Give me your goals. Head Work is a must screw in studs, guide plates, Double springs minimum, VTO seals. Scorpion or Harland Sharp or Howards or Crane or Lunati rockers. Stay away from Comp Cams or Proform especially ProComp. To get into the 450HP with double humps mild port matching of intake manifold is a must if yous is 7101 Edelbrock. A RPM Air Gap is worth 12HP 15 tq better as cast and port matching,plenum polish, full runner debur, 1in. Spacer will add 25-32HP 20-26tq over the 7101. It all depends on your goals. I personally have no problem driving a 3500 Stall converter with 4:10s daily killing the pavement and getting the neighbors and cops pissed off. 8) I like that radical idle and drive my engines to their intended purpose of only performance screw that POS Comp Thumpr WanABe cam their junk and don't last from their Chinese or blemed Cam Cores. A scat 9000 crank 4032 piston forged I beam cap screw rods All internally balanced will have a great foundation without NO2. If your going to spend for an H Roller conversion make sure Everything is machined to last which is very $$$. But most parts Can be reused on the rebuild or freshen up, if you look at it as an investment. Give me your opinion of what you'd like and don't like. |
Im putting it in my 72 nova im going to make it an street /strip car that runs off pump gas and the intake is an holley high rise intake
Ditch the heads. By the time you pay to upgrade the seats to run unleaded, you can buy a better flowing set of heads for the same money...
Well hopefully its not the contender manifold,better the street dominator or better Strip Dominator. If the are the Strip or Street Dominator I got a couple of H-roller set ups that can make you fly. First Stay away from Comp Cams
lately they have been importing Asian cores last Feb. I ordered a customer a mild Solid Roller and sent me cast iron Solid roller,very piss poor and another ocasion on a H-roller a few years back ordered a 4/7 swap cast iron gear for a mild stock repalcement sent me a cast oron roller cam that was 15'' off the cam card. They used to be like Crower,Lunati,Isky and others now they are so big customer service is piss poor. Ok with the intake,heads, that you provided using a Holley 750 or better a Speed Demon 650 or Quickfuel 750 carb I got a couple of grinds that will make you happy. 1). Most Sreetable Very Similiar to a Mech. Tappet Isky 280 cam 3000 stall By Doug Hebert CCH-244 525/525 280/280 adv. dur. 245/245@50 on a 110 lobe sep. I'd install advanced 2 degrees to give a 108 lobe sep for another 10-12HP. Also get it with a cast iron Distributor gear for much less headaches and I'd top it off with a 4/7 swap for a smooth torque curve. All for an MSRP of $299.99 for an H-roller,cast iron Dist. gear and a 4/7 swap all made in America. $219.99 just for basic H-roller bronze Dist, gear standard firing order. RPM range 2500-6700 2). A liitle more Radical Herbert Cam H-roller. For Street/Strip 3200-3500 stall CCH-240 300/310 adv. 240/250@50 535/535 on a 110lobe. $219.99 base price. All the goodies 4/7 swap cast iron gear.$299.99. RPM range 3000-7000 3). Lunati VooDoo •Advertised Duration (Int/Exh): 294/302 •Duration @ .050 (Int/Exh): 243/251 •Gross Valve Lift (Int/Exh): .560/.565 •LSA/ICL: 110/106 •Valve Lash (Int/Exh): Hyd/Hyd •RPM Range: 2800-6400 Part number 60113 3200 stall Super Aggressive power and torque. $320.95 4). Howards H-Roller 110345-10 300/306 adv. 560/580 247/253@50 on a 110 lobe. 3500 stall 2800-6400 RPM Range for $265.99 through Competition Products 5). Just about as radical as an H-roller can get without too much trouble Another Hebert cam 560/580 280/285 250/255@50 on a 110 lobe part number CC6L for #219.99 with all extras $299.99 Needs 3500 stall a little on the big side but will run good. Let me know what you think. |
I like the howards H roller cam. Were is an good place to get that cam :P
The Howards cam you can get through Competitionproducts.com or better phone number 1800 299 0199.
The rotating kit that will last alot onger than a stock bottom end without breaking the bank you can find it on ebay through Skip white performance for $849 plus $59 shipping that includeds a Scat 9000 crank.Forged flat top pistons,h-beam rods,all bearings,balancer,flexplate and all comes already balanced ready to assemble this kit is externallt balanced and have used these same kits and support 540HP without problems. I've used several at 520HP to 560HP. Good Stuff. Phone number 1-423-722-5152 or 1-877-383-5152 Here is the link to the ad http://www.ebay.com/itm/SBC-CHEVY-SC...item519f1f8392 @30 over will give 11:1 compression he has a dish piston kit to give you a more friendly 9.5:1 compression. You'll have to put at least $350 in labor for the heads from milling to install hard seats, install screw in studs with guide plates. I'd get a set of RHS or Dart heads that already the hard shit done already to save on cost and get more power. On a RHS 200 head with a mild H-roller will get you in the 500-510HP and 490tq or a Dart head will work fine as well. Let me know what you think. |
Yea i like that kit and that cam. But idk what im going to do with the heads yet.but an buddy of mine has an 400 crank and he wants 50 bucks for it what do u think about that crank
Well a 400 crank will work take it to a machine shop to have it mains turned down,be sure you get the flexplate and especially the balancer.
Be sure to use 350 rods in a 5.7 or 6in length. Their is another kit I've used a few times that was very affordable is ths one http://www.ebay.com/itm/Eagle-Sbc-St...cb7401&vxp=mtr Pretty inexpensive with free shipping after all the machine work and balancing and parts the rotating kit will only be $60-$100 with better parts but I've used 400 cranks several times in the past in 383 builds but I've always used a light to ultra light piston to get the big RPM's quick but back then I was using mechanical flat tappets and had plenty of fun. All together you can build a 383 today using a purchased machine block,with the kit listed above machine you heads,Solid flat cam,carb,distributer for under 2300 bucks. I'd look around for a 383 that is a complete shortblock why because you'll save on average $250-500 but be sure to get through a quality shop that specializes in HP not a POS Foreign and Domestic Machine Shop. |
Ok then thanks bud i appreciate it
| All times are GMT -8. The time now is 03:20 AM. |
