-   -   496 stroker (https://www.racingjunk.com/forums/showthread.php?t=31917)
sethz79 04-02-2012 06:17 AM
496 stroker
Hi guys, I'm new to this and new to Big Block Chevy's. I'm having my bottom end built out of a 427 tall deck truck block. However a little confused about what kind of top end to buy. I want between 300-320 cc. intake runners and 119-124 cc. combustion chambers for heads. Any ideas for what brand? Anyone know where to go for a dual plane intake?
My application is four wheeling so I don't need real radical stuff.
markdunlap 04-02-2012 01:57 PM
496
You can get more interest if you post your question under the ENGINE TECH section of this forum.
I can only talk about a 496 from a drag/bracket race combo.
320 heads like DART PRO 1 325 or RHS 320
119 combustion chamber.
12.5 compression.
Roller cam .725" lift, 276/284 duration, 110 lobe seperation. (Best to get a professional cam guy to make the selection once everything else is known.)
Single plane intake, Edelbrock Victor R.
1050 Dominator carb.
Forged crank and H beam rods with L-19 bolts. Eagle quality or better.
2 bolt block is OK with ARP main studs, line honed.
Best machine shop you can find.
ajk 04-02-2012 02:17 PM
DITTO!!!
I would guess many engine guys do not even look at the General Discussion section
sethz79 04-02-2012 05:28 PM
ok. thanks.
