-   -   anyone run their hot rod on e85 (https://www.racingjunk.com/forums/showthread.php?t=31836)
hotrod1994 03-15-2012 09:03 AM
what does it take to run a mild sbc 9.5:1 mild cam 1.94 heads on e 85 just looking into it
thanks logan
roadkill2 03-15-2012 09:56 AM
Far as I know, you have to have the correct gaskets and "O" rings in your fuel delivery system, and of course, proper jetting . .
There's guys that come up here that's a lot smarter on Alky carbs than I am . . I have always worked with straight Methanol or Ethanol through an Enderle injector . . Dunno much about carbs, yet . . But I'm learning . .
It gets a bunch simpler when you use a Throttle Body Setup or something similar. You let the computer figure it all out . .
curtisreed 03-15-2012 09:59 AM
http://raceone85.com/
http://www.e85forum.com/forum-1.html
http://www.horsepowerinnovations.com/product.html
http://www.marksullense85carburetors.com/
http://www.e85carbs.com/
hotrod1994 03-15-2012 11:49 AM
ok thanks
cncmotorsports 03-16-2012 06:37 AM
All you need is an E85 Carburetor.
E85 is more corrosive, so you will have to maintenance your fuel system a little more often.
