transmission problem
I have a powerglide which I recently rebuilt. We put in a new 588 bbc, and new converter. When motor comes up close to stall, the car breaks loose. won't do it at lower rpm. Any help as to where I should look, please let me know.
Just to confirm terminology; What exactly do you mean by 'the car breaks loose' ? |
when the transbrake is set and i am trying to stall test the converter the car moves forward at 6000 rpm it will not do it at 5000. i dont know where to look to try and diagnose the problem.
How many reverse clutches? sounds like reverse clutches not holding.
Transmission problems
What I mean is the car trys to move with the brake set, It has 5 clutches in reverse. Thanx
Might correct the problem by re-adjusting the band, instead of backing off 3 1/2 turn try 3 turns.
Just a thought :?: Zip. |
Sounds like you might have a worn pump and not producing enough pressure.
TS1955 |
Did you check what we talked about the other day? If you need any help, you know I'm less than a mile and a phone call away...
Johnny |
transmission problems
ok guys, found the problem, it was in the valve body, I fixed it. Thanks for everyones input.
| All times are GMT -8. The time now is 09:17 AM. |
