-   -   need a cam for a 496 BBC in a heavy car (https://www.racingjunk.com/forums/showthread.php?t=31752)
olds48 02-29-2012 02:10 PM
What have ya'll used in the past with good success?
The car is 2990 lbs without driver
1/8 mile only
Canfield heads
11.2:1 comp
Th400
33" tire with a 5.14 gear
Its setup with a solid roller now
Naturally aspirated,of course
I've been 6.62 with the car and it think it may go a little faster as is,but my 60' sucks.Best 60' of 1.44.
Any opinions welcome! Thanks
bbchevy 02-29-2012 03:18 PM
Re: need a cam for a 496 BBC in a heavy car
1/8 mile only
Canfield heads
11.2:1 comp
Th400
2990 is Heavy?Man I'm @ 3035.
My Cars got a 496,but i'm @ 14.5 1
Dart 355CNC
C/Cams CCA11-736-9
Glide 4.70 gear 10.5x33,8"PTC 6300 Stall
Best pass-5.601~124, 60' 1.22-.24
You Deffinately have ALOT more Lauch RATIO than me,which should Help you?
Other than the Compression,would like to know what Head you have?Along with stall,Intake and Carb or INJ.,Gas or alcohol?The more Info the BETTER,...?
I have a couple Rollers left here,think I have a 748-748?
But I will look into a cam for you w/the 11.2 Static comp?
Later
G 8)
zipper06 02-29-2012 06:03 PM
468" i built for my friend. Car weighs 3700 lbs without driver. Driver weighs a little over 200 lbs.
BB 2 Extra heads ported
turbo 400
1050 Dom.
4.56 gear
15X33X15 GY's
No fiberglass except hood and trunk, all roll up windows
It runs 6.38 @ 109 mph on motor with 1.44 60'
Runs 6.18 @ 114 mph 1.38 60' with 200 shot of nitrous
9.77 @ 138,5 in qtr with 200 shot nitrous.
Cam installed at 106*
It has a stock GM steel crank and 804 rods with good bolts and and forged Probe 10.4 pistons, roller top end. i used a small cam because of the weight of the car.
I'm not kidding it totally surprised me on the performance :oops:
http://img.photobucket.com/albums/v5...amheavycar.jpg
http://img.photobucket.com/albums/v5...Biscyne001.jpg
TheYellaBrick 02-29-2012 06:31 PM
I never get tired of seeing that big black 'n' flamed boat in that wheels up attitude !
olds48 02-29-2012 08:20 PM
That makes me wanna put my 496 in my '66!
At a track full of Fox bodies I'm considered a heavy car
See,all you guys are running way faster than me,I dont know why my car is a slug. Our track is a true 660 feet long and I turn 103-107mph when i have it detuned to run the 6.95 index. All out the best mph it has turned is 112 so I know it is making good top end,just wont leave hard.
My heads are the bigger of the two Canfields, I think it is a 335 runner???
2.25 and 1.88 valves
NO port work whatsoever
I shift a 6200 ( i know...) and it runs fine on pump gas. I went ahead and ran on VP 110 last season and saw no difference. I'm gonna return to pump gas just for cost reasons this season. My converter is not real loose. In high gear I can stall it on the foot brake to about 55-6000. At the line it will only foot brake to about 3000 max before pushing thru the brakes. With a 1600 rpm launch (approx. i dont run any staging controls) it will flash to about 4000.
Anymore info needed? Thanks for the help so far.
You guys are making me jealous.If at all possible,I would love to be able to run the 5.95 index naturally aspirated,but I think I will need to bump my compression to make that a reality
zipper06 02-29-2012 08:34 PM
The car has a Trans brake and a 5500 stall converter. It sounds like your converter may be a little loose, if you can stall it to 6,000 rpm. (JMO) We shift at 6600.
We go to the shell station and fill up the tow vehicle and the racecar, it's never seen race gas. As a matter of fact it has mufflers also, but are loosened and shifted to one side at the track. This car can be driven to Sonic, or anywhwere in our small town, with the mufflers connected. There's a 10 gal fuel tank in the trunk, 2 seats and harnesses. It doesn't load up on the gas or overheat on the street and idles at about 900 rpm. Like i have said before i don't know how much HP it's making, but it's got to be close to 700 i would think.
olds48 03-01-2012 12:01 PM
I run thru an air filter and mufflers. Of course my "mufflers" are 4" bullets. If you can call those mufflers. It only stalls that high in high gear,I wish it was a tad looser. It really starts pulling at about 5000 rpm. I think my motor is over-cammed for the compression it has. I'll get my cam specs up when I find them. The lift is in the high 700" range and the duration is really probably too much for my comp ratio. Aah,the joys of buying other peoples take outs :D Its a lunati cam. pretty sure the part # is 50210. But Ill find out and get back.
bbchevy 03-01-2012 01:57 PM
50210
You NEVER have Posted what INTAKE and carb you have?
Wow,Way tooo much BumpStick!!!
320/334
766/744
110 LS
108
Power band on the Cam,45-8200.
You NEED 6000 min.Stall.But with that Duration,it will NEVER Happen!
Your just Barely touching the Power when you Shift!
Need to Shift @ 7500.You would Be surprised,how it will Pull above 6500 to 8000!
Change the Stick,and get the Converter to PTC and have the Boys LOOSEN it up!!
Later
G 8)
zipper06 03-01-2012 05:57 PM
I agree with G/Greg, way too much cam. I did forget to mention that we launch @ 4600, and have cheapie headers, either 1 7/8" or 2" i've forgot now. I think we paid $190.00 for the headers with muffler flanges and 3 1/2" collectors. O'h by the way PTC is the best in my opinion (sheeh!! :oops: also a person friend for yrs. and yrs.) and the only converter i and most of my friends run. I also forgot to mention the car runs low 10.30's@129 on motor only.
Greg, i'm not so sure i would loosen the converter up with that heavy of a car. It should have plenty of torque if he goes to a smaller cam JMO
I did have the car listed on RJ for $18,000.00, running. I had a person PM me and said he would like too buy the car but don't believe what you say. I told him send me a $500.00 deposit and bring the rest of $17,500 in cash with you. We'll go to the track and if it doesn't run that i'll give you back your deposit and split your gas cost for the trip. Patented saying (bobr) K'O'ed first round. Never heard from him again.
olds48 03-01-2012 09:46 PM
Oops,sorry! It is a 1150 Dominator on a Professional Products intake. Everything is portmatched to a Felpro 1275 ( I think thats the one). I DID do alot of clean up work inside the intake due to HEAVY casting flash,but the runner seem to have a nice shape/flow to them. The previous cam I had was a Comp Magnum
Previous cam: http://www.compcams.com/Company/CC/c...?csid=497&sb=2
Your specs on my current cam are correct. I knew it was waaaay too big but it got for a song ($80?) and I did pick up two tenths with it. I have tried shifting as high as 7200 and saw no improvement at all. I believe the heads are tapped out at that point. They flow,out of the box, only 375 cfm at max and they peter out above 650 lift. The extra lift probably hurt me. The improvement I did see was probably a result of the extra duration. That Magnum cam had a real lazy lobe due to being a "street roller" as it is advertised. With the magnum can the car never 60'-ed better than a 1.650 :oops: but would pull like mad on the topend.
Another bit of info to throw in the mix. Like I said before,it has a manual vb th400. Twice I have accidentally left in 2nd gear. 60 foot,et and mph were all unaffected by this. Too much gear? Need a 'Glide? Just putting it out there.
Thanks for the advice so far.I will say one thing...this cam sounds sooo good!It surprised me it will idle at 1,000 rpms,sorta,but it sound healthy! I'm wondering if I should re-cam or if I should repiston with...what would you say...14:1? Or do you think I am at a lack of airflow thru the heads for my current cam?
