A-ARM 2x3TUBECHASSIS HELP
I just picked up an old 2x3 a-arm front clip I think it an A. R .T.type. I have a back half 68 camaro Round tube chassis. OK, heres the question, i dont have the old front clip in the car any more and was trying to figure out where i should mount this clip and what height the center of spindle is. The other prob. is someone cut the rest of the fram connections off. I only have the front clip to where it would start to go under the fire wall. If you need pics i will get them or if eaiser i can call.Thanks for reading. Paul
Post up some good clear pics and you'll get more help. Lot of fabricators on here.
As Double D said ya need to post some pics! But shouldnt be that big of a deal.
post subject
Thanks for replying. i will get some up
Re: post subject
Zip. http://www.appliedracing.com/ |
post subject
I have pics, cant figure out how to get them up
Re: post subject
Zip. |
Re: post subject
Zip. http://img.photobucket.com/albums/v5...ulschassis.jpg http://img.photobucket.com/albums/v5...schassis-1.jpg |
GOOD ! These show us what you are working with !
Now we need 4 pics of the car you want to mount this in, please. Ideally one facing the firewall, a shot of the underbody at the firewall, one facing forward from the rear seat area, and one facing forward from the rear end area. |
post dubject
Im running a stock fire wall on 68 camaro. The plan was to tie into the main cross member behind the drive seat where my ladder bars are.Because the car sits low I think if I put in the front clip i have to cut away the floor either all or just where the rails would tie into the cross member. I will get some pics to Zip to post. Thanks Zip
| All times are GMT -8. The time now is 09:36 AM. |
