-   -   aviation fuel (https://www.racingjunk.com/forums/showthread.php?t=31629)
hotrod1994 02-02-2012 12:05 PM
aviation fuel
can i run aviation fuel in a sbc with 11:1 with same carb and same set up for gasoline
TS1955 02-02-2012 04:20 PM
You'll probably need to go up a couple of jet sizes.
TS1955
roadkill2 02-02-2012 04:26 PM
If you're set up for 100-110 octane, you shouldn't have to change anything. Dunno which "Avaition Fuel" you're gonna be using. There's several grades of AVGas.
fast75vega 02-03-2012 02:38 AM
i run the same jetting in my drag car... for both fuels 112 and av gas(100LL) and the car runs the same :wink:
hotrod1994 02-03-2012 08:17 PM
ok i would run the 100 low lead
outlaw256 02-04-2012 03:48 AM
running low lead kinda helps defeat the purpose. we ran av gas back in the 70s. 112 or 115 dont remember but it also had a high lead content which our heads at the time needed.ran a 12.5 .1 327 tunnelrammed with a 4 speed. . ran that same engine on the street and strip. and i drove it hard. sold the car in 89 and it ran as strong as when i first built it,
roadkill2 02-04-2012 08:43 AM
Honestly, if you're going to buy something other than "Pump Gas" (which is available in some areas as Sunoco 110 or 112 octane) You're far better off buying and using racing gasoline of your octane choice. The quality is better and you always know what you're getting . . Thus your "Tune Up" is consistent . .
fast75vega 02-04-2012 02:02 PM
i really dont think that the quality of race fuel is better then the quality of someone 10k plus feet off the ground....lmao :wink:
jmarksdragster 02-04-2012 02:44 PM
Even the LL contains 1.2 to 2 grams TEL per gallon. As far as running it, with 11 to 1 you will be quite safe as long as you jet it correctly. And avgas has very good vaporization characteristics which is a good thing, if you get some do a test. Find a piece of metal to put some on along with some pump gas and if you have some racing gas. See which one vaporizes first, and which leave deposits that don't vaporize. Any that don't will be very difficult for the engine to burn. Depending on what you run currently for fuel you may need to jet up one or two jet sizes.
hotrod1994 02-04-2012 08:52 PM
jmarksdragster- good point
i would run race gas but 7-8 bucks a gallon compared to 5 bucks for av (here in wi) is quite a bit for a broke man like myself
