-   -   cam help (https://www.racingjunk.com/forums/showthread.php?t=31516)
hotrod1994 01-10-2012 02:11 PM
cam help
i need cam ideas for a pump gas 355 that will get me the most power possible looking for well over 500 more like 575 600 + but i need it to be able to be street able doesn't have to be great on the street just enough to manage looking for one helluva street car
any ideas throw them at me
thanks Logan
will have 10-10.5 :1
pro comp heads ( i know but im on a budget)
scat 9000 crank
forged i beam rods
will turn it to 7,000 or more when im racing i know the limits scat has on the crank but if she blows she blows that racing
build it,break it, fix it and repeat
bbchevy 01-10-2012 02:24 PM
Well,?If it has Forged Pistons?
Put a Cheater Kit on it,and Let it HAPPEN!!!!!!!
Later
G 8)
hotrod1994 01-10-2012 02:36 PM
nah just hyper
cncmotorsports 01-10-2012 05:41 PM
The pro comp heads will be the limiting horsepower factor in your build.
Solid roller or hydraulic roller?
hotrod1994 01-10-2012 06:21 PM
solid
hotrod1994 01-10-2012 06:26 PM
this build is in the planing stage im 17 and i have a 76 camaro with a mild sbc make 350 hp maybe and im looking to upgrade by about 200 horse power but ill take what i can with my budget so im just getting idea's if i end up falling into some money or find another job ill upgrade to some 210 afr's my seasonal potato harvest job ended in October and thats the olny reason the car runs now is cause of that job and jobs for a 17 year old are getting harder to come by
but thanks for the help guys keep the info coming
JEFF69Z28 01-11-2012 02:30 AM
THOSE AFR 210'S WILL LOVE THIS SOLID ROLLER CAM.
645/633,WITH 1.6 ROCKER ARMS INT/EXH WILL CHANGE TO 688/674
111* LOBE SEPERATION
260/264@50
THIS IS A COMP CAMS CAM,IF YOU LIKE SOMETHING BETTER CALL STRAUB TECHNOLOGIES(421-391-7774) AND ASK FOR CHRIS HE'LL GET YOU STRAIGHT.
burgessdg 03-09-2012 08:55 PM
600 HP out of a 355 with 10-1 compression and a cast crank? 500 HP is pushing it. And you won't get to that without juice. And 7000 RPM? Why build something that you are going to blow up? Not very smart for your budget. Shoot for a real HP #.
hink 03-10-2012 05:14 AM
Re: cam help
thanks Logan
scat 9000 crank
forged i beam rods
600 horse on a stock block HMMMM
600 horse 10:5 compression HMMMM
600 horse on a cast scat crank HMMMM
600 horse Procomp heads HMMMM
600 Horse streetable HMMMM
hotrod1994 03-10-2012 06:07 AM
550 600 is very do able with a stock block the Nodular cast steel! crank not cast iorn it will be to it's limits the 10:1 compression im not sure what i was thinking when i put that wasn't paying attention i guess
this is out of the picture now im gonna build my camaro as a street car with 450-500 hp
my uncles got an s10 that im looking to buy and back half it and such and put a 650 + hp fully forged 406 sbc with 14:1
