-   -   fox body max tire width (https://www.racingjunk.com/forums/showthread.php?t=31507)
notchmodfox 01-08-2012 07:03 PM
Just hoping someone could share a little knowledge with me on this.I have a 91 fox body with stock width 8.8 and I'm wanting to put a set of et streets or maybe drag radials on it.Just wondering about max wheel width and back spacing along with tire size that i can clear.I'm planning on running a 15" wheel.
DirkaDirka 01-09-2012 07:39 AM
O got a 90 fox and it has a mini tub done to it. I think (if I can remember right) that you can put a 10in wheel inside the well without it hitting. I dont know about the backspacing and all that tho.
notchmodfox 01-09-2012 08:43 PM
Thanks man I think your right about the 10" wheel.I thought I was told that with a 10" wheel with 6.5" of back spacing you can clear a 325/50/15.Just wondering if anyone had done this for sure
mikey82gt 03-17-2012 09:27 PM
If your wanting to keep the quads you will need to take and flip them 180. 275 tire would be about the widest you can fit. Hope this helps.
