Help with 383 pistons
I'm lookig to build a sbc 383 I have the block,crank and rods can I use the pistons out of my 355?
Is a 383 a special piston l or just a 350 .30 over piston? |
Nope the pin height is in the wrong place, the pin height needs to be 1/8" shorter to the piston deck for a 3 3/4" crank.
Zip. |
Ok thanks! That helps alot.
| All times are GMT -8. The time now is 03:39 AM. |
