rocker arm ratio
is there anything i have to do differently to run a 1.6 ratio on a sbc instead of a 1.5 rario
just install them and the push rods... then turn it over by hand to check clearances to make sure your not bottoming out the valve/springs. might have to change push rod length pending on cam size
ok it gonna be a farily mild cam solid flat tappet 525/525 with the 1.5 ratio
and is it worth the extra ratio it will be a 355 with 10:1 c comp 294s soild cam pro comp aluminum heads hurricane intake and a holley 750 looking to get 450 out of it
comp cams cam quest said 500 hp with the combination and that cam |
Check the wipe of the rocker on the valve tip. You might need to alter the push rod length.
| All times are GMT -8. The time now is 01:27 AM. |
