Gutted the interior
Started the interior teardown today. Plulled the cluster and dash. Someone had already butchered the cluster before, 2 bent metal tabs screwed into the housing was all that was holding it in place!
http://s3.racingjunk.com/ui/4/70/24601704-296.jpg http://s3.racingjunk.com/ui/2/72/24601722-406.jpg http://s3.racingjunk.com/ui/5/72/24601725-377.jpg http://s3.racingjunk.com/ui/8/72/24601728-356.jpg Took the front seats out and then removed the dash, a few rusty screws and it all came out. http://s3.racingjunk.com/ui/1/89/24601891-419.jpg http://s3.racingjunk.com/ui/3/93/24601933-224.jpg http://s3.racingjunk.com/ui/2/95/24601952-416.jpg http://s3.racingjunk.com/ui/5/03/24602035-929.jpg http://s3.racingjunk.com/ui/5/00/24602005-439.jpg [/img] |
Dash is nice minus the big warp in the top, gonna work on that. It has no cracks or damage so I gotta save it!:)
http://s3.racingjunk.com/ui/3/10/24602103-204.jpg http://s3.racingjunk.com/ui/1/14/24602141-092.jpg http://s3.racingjunk.com/ui/8/16/24602168-080.jpg http://s3.racingjunk.com/ui/7/19/24602197-596.jpg So the floorpans have been replaced on both sides, decent job but they never painted the floor. I had some leftover POR, so a good scuff and slap it on! http://s3.racingjunk.com/ui/3/24/24602243-224.jpg http://s3.racingjunk.com/ui/9/28/24602289-683.jpg http://s3.racingjunk.com/ui/2/32/24602322-839.jpg http://s3.racingjunk.com/ui/8/33/24602338-089.jpg http://s3.racingjunk.com/ui/9/41/24602419-441.jpg |
http://s3.racingjunk.com/ui/7/42/24602427-274.jpg
http://s3.racingjunk.com/ui/7/44/24602447-028.jpg http://s3.racingjunk.com/ui/2/46/24602462-683.jpg http://s3.racingjunk.com/ui/2/74/24608742-529.jpg The cooling fans were wired up to run all the time so a new thermo-switch from Jeg's and a little wiring and now they work properly http://s3.racingjunk.com/ui/3/47/24602473-834.jpg http://s3.racingjunk.com/ui/6/47/24602476-630.jpg Picked up 3 rolls of Peel & Seal from Lowes today. Start on that next weekend. Happy New Years guys!:) |
Looks good Harbone. I'm sure it will look as good or better than your last few rides, and they were all sweet. 8)
QUICK MARK---DID YOU SEE THOSE WORKBENCH CHAIRS HARBONE HAS IN HIS GARAGE ---MOPAR !!!!!!!
You like those? The white one is actually pretty old, found it in a storage room at a Dodge store I used to work at. I got about 5 of the black ones, intended to build a bar but put in a pool table instead.
I CAN'T SAY TOOOOO MUCH--I HAVE A V8 S10 SITTING IN MY GARAGE RIGHT NOW :oops: :oops: :roll: :roll:
BUT I DO LIKE THE MOPAR SEATS 8) |
'Bone, You're one of those typical hotrodders that just can't leave ANYthing alone for one single second ! :P :P :P :P
Looks like you found some 'shortcuts' from previous owners ! I hope the drive train is in better condition :D It's always the stuff you can't see that can bite ya ! So are those stock or modified OEM bar stools ? |
Them barstools are stock!
I dont have to worry about the drivetrain, previous owner knows what he was doing in that department. He gave me plenty of receipts and a ton of photos he took while putting the motor together. I already scored a cluster housing with all the tabs intact from a guy. I just have to get the heat gun out and some patience to straighten out the dash warp. The paint and the engine compartment are beautiful so I had to do something with the interior. Thats one thing about living in Illinois, January through March is the best time to work on the warm weather toys :D |
Busy week at work and woop ars tired but I did a little work when I got home. Picked up some valve covers this week, GM Performance with holes and baffles so I can hook up a PCV hose. Plus they look good and almost match the car color of the car perfectly. Heres a pic of the valve covers that were on it, TIG welded drag race parts.
http://s3.racingjunk.com/ui/1/64/24535641-812.jpg Here is the new ones. http://s3.racingjunk.com/ui/1/13/24681131-153.jpg http://s3.racingjunk.com/ui/9/11/24681119-613.jpg http://s3.racingjunk.com/ui/3/12/24681123-765.jpg It looks a whole lot better! Gonna start putting down the sound barrier tomorrow on the floor boards... |
| All times are GMT -8. The time now is 08:33 PM. |
