-   -   SBF 393 stroker (https://www.racingjunk.com/forums/showthread.php?t=31454)
championcity 12-27-2011 03:42 AM
SBF 393 stroker
I have a sbf 393 stroker with procomp 210 heads and 595 lift hyd. roller cam, flat top pistons 10:1 compression, single plane intake and quick fuel q750 carb. Would like more horse power, looking for a top end combanation, heads, cam, intake and carb. ect. any suggestions?
JEFF69Z28 12-28-2011 03:22 AM
Build a chevy motor
BEAST477 12-28-2011 12:35 PM
Is this a street or strip engine? If it's strip I would raise the compression then a good port job if the heads are untouched. If it's street at least a good port job.
cncmotorsports 12-30-2011 07:09 AM
Call us, we can set you up with a top end kit that will pick up that engine combo.
