CAL-TRACS FOR THE S10??
Getting ready for the suspension on the v8 square body.
leaf springs but can't decide on the bars [mostly street with some drag racing ] about 350 horse at this time] with an auto it has the ZQ8 suspension on the rear with the anti hop shock on it anybody got ideas or a set laying around?? thanks solid spring bushings/poly bushings / clamping???? IDEAS 8) |
How many leaves in the stack?
2 leaves and an overload spring
With no more HP than you expect to have, i would think just a set of slapper bars would work just fine. I've seen cars work with them with a lot more HP.
JMO Zip. |
I am planning to clamp the front half also--we might try the slappers first [caltracs can get expensive!!!] :roll:
I'd also take that overload leaf off, unless you plan to carry a heavy load, and add a good set of 50/50 shocks.
A long time ago we ran a 431" b/blk 67 Camero conv. That ran 10.89 @ 127 MPH, with the mono-leaf spring and slapper bars. JMO Zip. |
| All times are GMT -8. The time now is 03:46 AM. |
