-   -   messuring egt (https://www.racingjunk.com/forums/showthread.php?t=31415)
hotrod1994 12-18-2011 05:55 PM
messuring egt
if the exhaust gas is 1200 degrees would the header also be 1200 degrees and would i be able to check the the temp with an inferred thermometer?
thanks logan
zipper06 12-18-2011 07:27 PM
If you are able to ride on the fender and point the inferred gun at 100 mph you can, it's not going to go to 1200 degrees except at wide open throttle, it should idle around 500/700 degrees.
hotrod1994 12-19-2011 12:54 PM
ok thanks zip
ewing 01-03-2012 10:01 PM
The temp on the outside of the tube will be lower btw.
Even with egts inserted in the tubes, the readings often tell more about the tips protrusion into the exhaust flow,
than the actual exhaust temp.
