rpm help
what kind of rpm's will i turn through the taps with the set up im looking to go with
76 camaro about 3400 lbs with driver mild sbc with STOCK bottom end mild cam 477/477 lift and268/268 durration 1.94/1.5 heads milled for 9.3:1 th350 3200 stall 4.88 gears (open to suggestions for best results) but looking to stay higher to get off line decent 29x12.5 mt sportsmans stock bottom end 350 with mild set up just looking for what the rpm's will be at the end of the 1/4 mile im willing to push this thing to the absolute limit but will 4.88's be to much i can get a set cheap (BUY IT,BUILD IT,BREAK IT, AND REPEAT) |
I had a stock 350 with a 470 lift cam
turbo 350 3600 b&m convertor 4:86 gears went through the finish at 5800 on a 29 tall slick no I dont think the 4:88 would be to low I would quess your rpms will be 5700-6300 |
what would she run in the 1/4
| All times are GMT -8. The time now is 12:20 PM. |
