1000 HP ? second opinion please
Hi after peoples thoughts on a 440 allready blown BDS 871 engine having the following added when rebuilding, i am looking to make around the 1000 hp mark.
440-H1-1 heads bare--Indy 440-R4-10 External oil kit OPT-H01-A Std shaft mount MPI-V1-440-1I 2.190" Inlet valves x 8 MPI-V1-440-1E 1.810" Exhaust valves x 8 ALL-S2-K950 K motion valve springs ALL-L3-611-1 10 Deg valve locks ALL-R1-732T 10 Deg valve caps ALL-V3-529V Viton valve seals 440-V5-6 Valley cover plate 440-I4-20 Blower manifold 440-R4-4-1.5 rocker arms 440-R4-11 Rocker studs 440-R4-14 Rocker shafts 440-P5-9K Push rods 440-H3-16 head bolt set Eagle forged stroker crank 4.375" stroke H-beam conrods 7.1" JE Blower forged pistons Total seal rings Cam bearings ARP main studs Main bearings Rod bearings Oil pump oil pump drive shaft and trans TF727 with 5 plate clutchs, Billit Fwd drum & input shaft. Rev shift patten trans brake. Ridgid front band 5.0 ratio band apply lever Deep alloy Sump pan kit Alloy direct clutch drum kit Rear support kit with roller bearings Super Spragg 4 pinion gearsets well this is what i am being recomended and as i am spending a fare amount i would be very interested in replies Thanks Richard |
Do we have to ask twice?
| All times are GMT -8. The time now is 09:35 PM. |
