400 sbc block
I'm needing some advice. I have a 400 sbc engine that has been bored 060 over to 4.185" with a 3.48" forged sbc crank. I ran it in bracket S-10 without problems. While getting it ready to put in a altered chassis, dropped pan and discovered small pieces of someone else's dipstick. So I tore engine down and now don't know whether to rebuild it or not. I want to put 12.5 or 13.0 cr pistons in it, and make about 625hp, but I am worried about thinness of cylinder walls. I should also mention that it's a 2 bolt block without block filler. Thanking everyone in advance for their advice.
Re: 400 sbc block
Filling the block does nothing to make the webbing of the block stronger and with the bigger housing bore and cylinder bores it weaker then a 350 block also 400 decks are weak as well. 400 blocks have a wider bolt patterm on the main caps making the caps weaker then a 350 block. |
400sbc
Thanks Hink for your info on the 400sbc block. I didn't know all of that. I have several 4 bolt 350 blocks, I'll rebuild one of those instead. Thanking you again. csx8506
You could always go with a dart shp block.
400sbc
Thanks Bluedawg357, That's a good idea, however, I'm a member of the "Cheapskate Racing Team"! Thanks csx8506
I also understand cheap skate racing. |
| All times are GMT -8. The time now is 12:16 PM. |
