-   -   sbc help (https://www.racingjunk.com/forums/showthread.php?t=31131)
gnos454 10-20-2011 10:00 AM
sbc help
sbc stroker , punched out 60 over , dart alu. heads, super vickter intake, just replaced head gaskets and intake gaskets (felpro) permatexed around water jackets on the intake and i'm still detting water in the oil , not as bad as before but bad enough,,,,
fast75vega 10-20-2011 10:17 AM
Re: sbc help
stock block? 60 over is pretty thin.......crack in the cylinder wall?
check the plugs to see if you have one that is really wet :wink:
itsabird 10-20-2011 10:23 AM
Could have gotten into water passage, when clearing the block for bigger stroke crank.
gnos454 10-20-2011 11:01 AM
sbc
yea just pulled all the plugs and spun the motor, stot water out of # five ,,,,,,,,,,cracked block ,,,,,bummer ,,,,, but got a spare block,,,
fast75vega 10-20-2011 11:49 AM
Re: sbc
i would never go 60 over on a stock block.... unless its the old heavy duty nickle truck block :wink:
gnos454 10-20-2011 01:58 PM
yea i hear ya , think i might keep the spare block @ 30 over and buy new pistons ,,,,,,
bbchevy 10-20-2011 04:46 PM
.060
You have NOTHING to worry about @ +.060 on a 350 Block,thats Only 4.060.A Stock 400 is 4.125.
Must have Ran a Couple DOZEN back in the 70's @ +.060!!!Never had a Problem,Until the 400 JUNK Came along,...............>
You say its a Stroker,....?How much Stroke do you have?
Later
G 8)
fast75vega 10-21-2011 04:06 AM
Re: .060
Later
G 8)
the only way i seen anyone get lucky with a 60 over block and not have the block cracking or running hot issues is when they used the HD chevy nickle block...... other then that i myself would only use a 60 std block for an everyday... go to work and home.... driver only :wink: 60 is just a waste of money in my honest opinion :roll:
outlaw256 10-21-2011 04:08 AM
aint nothing wrong with a 60 over 350. built many of them and run quite a few hard at the track. never had a minutes problem.
