-   -   Bad Heli-coil Repair, how do I fix? (https://www.racingjunk.com/forums/showthread.php?t=31125)
oldandtired 10-19-2011 02:34 PM
My customer just brought in a set of premium Dart heads but one exhaust thread is a heli-coil - but it will not thread.
1. Do I try to tap it 3/8-16 and Loctite in a stud?
2. Or, can I remove the coil and start over?
Thanks, Dave
TS1955 10-19-2011 02:47 PM
If it already has a Heli-coil the hole will be too big for a 3/8-16 tap. There is a product called a Keen-sert. It's kinda like a threaded bushing. See the video... Hope this helps.
http://www.youtube.com/watch?v=XyCTh23Z6o0
TS1955
markdunlap 10-19-2011 04:25 PM
Bad
If the helicoil is damaged, you may be able to use an EZ OUT to remove it and just put another Helicoil back in. Be sure to break off the tag at the bottom of the old Helicoil before inserting the EZ OUT if it is still there.
The KEEN SERTS are good too if there is enough material around the hole to let you go bigger.
gearhead1011 10-19-2011 06:16 PM
Don't try to tap a heli-coil. The tap will jam and possibly break. You can just take a sharp pick and bend the top of the coil in and then remove with needle nose pliers. Then you can clean up the threads with the heli-coli tap and install a new heli-coil. If it's too far gone for that then use the keensert.
fast75vega 10-19-2011 06:30 PM
yes..... X2 :wink:
oldandtired 10-20-2011 04:34 AM
Thanks for your response. I'll work on it today and let you know.
oldandtired 10-21-2011 05:46 AM
Problem solved. The shadetree mechanic drilled the hole crooked (probably by hand) and trying to tighten the header, it stripped the new insert.
The only tools some mechanics should use is a wheelbarrow.
fast75vega 10-21-2011 06:03 AM
lol... i hear ya :lol:
