-   -   carb help!! (https://www.racingjunk.com/forums/showthread.php?t=31097)
hotrod1994 10-13-2011 03:01 PM
carb help!!
what kind of carb should i run i have a holley 750 and it's way to much carb motor sounds great but i think carb it too big due to lack of power it's pretty much gutless
should make around 325-350 hp
or do i look else where for the problem
its a sbc 350
i was think 600 or 650 what do i need
or how much can i jet the one i have down and still maintain good idle and top end 6000 rpm
9.3:1
1.94/1.5 heads
comp xe268 cam 477/480 lift
edelbrock tourqer intake
bluedawg357 10-14-2011 02:32 PM
I run a 600 cfm holley, on pretty much the same set up, I came up with 583 cfm using the formula, I wouldn't go over 650 cfm.
bluedawg357 10-14-2011 02:37 PM
Also your lack of power could possibly be from the cam not really matching the intake, good dual plane seems more a matched intake to the xe268h in my opinion.
fast75vega 10-14-2011 06:24 PM
sounds about right:) id run a 600 or 650 single pump carb
hotrod1994 10-14-2011 07:17 PM
ok thanks guys im thinking there is somthing wrong with the trans to it just doent move worth a dam but sound really healthy when idling and reved
