mechanical water pumps and fans
On a drag car that finishes the 1/4 at 7200 rpm can I use a mechanical fan, water pump, and thermostat, or do I have to go electric. Thanks for the input.
going elec. just frees up a few xtra ponies..... you can still run your mech stuff.
I go thru at 77-7800,mechanical fan and water pump,plus an alterantor.4 inch crank pulley,50% underdrive to slow things down.No thermostat,works fine for me.Bill.
thank you very much for the responses. very helpful.
| All times are GMT -8. The time now is 06:39 PM. |
