REVERSE FLOW WATER PUMPS AND RADIATORS
Are the radiators for a reverse flow water pump style gm's different then the regular flow radiators???
We changed the pump to a reguler flow sbc from a reverse flow but left the reverse flow radiator in place and now have a heating up problem!!! ANSWERS ANYONE ?>>>>>>???? |
If your're talking about a reverse rotation pump, you have to remove the serpentine belt set up and use standart rotation pulley set up.The radiator works the same on both.If you're talking a reverse flow LT1 I don't thing you can change without a diferent motor.Bill.
If you use the factory clutch fan from the reverse flow on the standard rotation pump you swapped to, it will overheat...
the 350 was a 1991 out of a van[ same as the radiator]
it is on the engine start up unit right now --no fan on the engine -but big fans blowing thru the radiator i have an older style radiator we are changing to tomorrow and trying that out it really acts like it does not flow properly thru the radiator --it gets 210 pretty quick--so we shut it down--sometimes in 2 minutes other times it will go 10 minutes before heating up by the way --NEW RADIATOR--NEW WATER PUMP-NEW BELT--AND NEW ENGINE BUILD :oops: :oops: :cry: :cry: |
That's what you git from straying away from the FORD camp........ :P :P
TRUE :lol: :lol:
This is for my sons S10 project :oops: :oops: |
| All times are GMT -8. The time now is 03:49 AM. |
