-   -   tranny leak (https://www.racingjunk.com/forums/showthread.php?t=31077)
rhino058 10-08-2011 02:04 PM
tranny leak
My th350 is leaking tranny fluid from a hole infront of the lines for the tranny cooler. the holeis on the passenger side and is untapped and ive haad the tranny running before i just put a trans pak from b&m in it. i'm thinking of plugging the hole but not sure if its anything important. wondering if anyone has any ideas
rob41willys 10-09-2011 07:29 PM
Are you talking about the hole for the vent?
rhino058 10-10-2011 02:44 AM
It could be i was going to just go ahead and plug and see what happens i started the motors to try to draw some of the fluid threw the tranny to see if i can add fluid now going to try later today hopefully works
rob41willys 10-11-2011 07:23 AM
If it is the vent DO NOT PLUG
fast75vega 10-11-2011 11:25 AM
the only vent i recall on the th350 was up on top behind the bell about half way back :wink: you sure its not the oring on the dip stick tube or the tranny kick down cable? does it leak when it sits or just when its running?
rob41willys 10-11-2011 01:41 PM
You are correct I was thinking powerglide. The vent for a 350 is on the drivers side at the base of the bell housing. Is there a kick down cable on this transmission, that would be located just below the fittings for the cooler lines?
rhino058 10-11-2011 03:54 PM
yea it only leaks when i was just plain adding fluid i started it for 30 seconds to suck fluid threw the internals so im going to try again to fill it tomorow
