2002 BBC 496 Engine
I just bought one of the GM 8 ltr Motors hoping I could make a 502 out of it only to find its a tall deck..Are there anything you can do with these?
502
Wanye,
I LOVE the 10.2!! Just put a Long Rod in the thing,if that all the Cubes you Want?If Not theres SEVERAL other combos,.........? What Stroke do you want to run?Is the Bore standard?4.470 I beleive,...? Later G 8) |
496
Std bore,I just tore it down & ut spun #2 rod bearing,,Cranks shot..Im not sure on the bore,I do know the 502 is a 4.47...
Since you have to have a new crank anyway I'd go ahead and put a 4 1/4 stroke crank in it, bore it to 4.5 and make it a 548.
496
According to specs it already has a 4.25 crank with a 4.37 bore & a 7. something rod..
Re: 496
Seems My Last 1 was a 4.50 Str.,6.700 Rod,1.240 Pin?That will make you a NICE COMBO!!! |
Re: 496
Seems My Last 1 was a 4.50 Str.,6.700 Rod,1.240 Pin?That will make you a NICE COMBO!!! Later! G 8) |
| All times are GMT -8. The time now is 01:57 AM. |
