-   -   Bondo Truckguard. Roll on Bed liner (https://www.racingjunk.com/forums/showthread.php?t=30926)
j120v 09-06-2011 06:49 PM
I just installed a roll on bed liner. I used the Bondo truckguard. I'm happy with the results but for a few things. 1st....The cheap ass roller that comes with the kit really only worked well 3/4 the way. 2nd...I would have liked to have a thicker layer. So here's my question: Is it possible to build up layers and if so....How would I prep it for the 2nd. layer? Also, am I screwed, if I decide to go with a spray in bed liner? Is it possible to go over my roll on liner? Thanks....
j120v 09-11-2011 01:59 PM
no one can help??
482 09-11-2011 02:24 PM
I would think all you have to do is put on another coat as long as it has had sufficient drying time between coats.
It is textured so it would not need sanded or anything.
I Also see no problem spraying on another bedliner if need be. 8)
