penske dbl adj coilover feed back
how many guys are running them and or switched from another brand. feed back please. thanks
well i did'nt get any response, so i went and got them any how. i guess it's a shot in the dark.
http://i437.photobucket.com/albums/q...P1010014-1.jpg |
IMO either the springs are to short or adjusted to high on the shocks.
I've never used them or seen anybody else use them. Most use AFCO, QA1 or Strange shocks. |
thanks rabitt, that was just for the picture. installed the spring collar was moved up a lot. i have now aprox. 2" shaft exposed.
You should be good to go.
Sorry I wasn't much help for you. |
Very good shocks, most dont use them as they are a pretty pricey shock.
Had a chance to get one at about half price and knew where it was coming from and it's use. Run it on a mono shock swingarm application. It replaced an Afco shock that worked real well and made the car better on marginal tracks. If it was not for the deal I would have stayed with the Afco but sure am glad I came across the deal and made the change.
| All times are GMT -8. The time now is 02:08 AM. |
