cam grind help
ok guys im looking for custom cam grind suggestions for a sbc it has
9.3:1 compression and i want a high lift lift nasty sounding hydrallic flat tappet that will work with my set up std bore 350 9.3:1 compression would like to run premium 91-93 octane 1.94-1.5 worked iorn heads torker intake/ but i may upgrade to a knock off of the victor jr holley 750 (yes it's a little big) mallory unilite and mallory hyfire 6 ignition it will have a th 350 behind it with a 3000 stall converter 4.11 gears im looking for a high lift nasty sounding cam that will work good with my set up and make lots of power through from abot 2,500/3,000-6,000 im open to any help or suggestions thanks logan |
cam
look at comp cam.........thumpr cams
Cam
Just installed a Mutha Thumper Hydaulic roller in a 377 SBC street/Strip Nova.
It does sound REALLY GOOD at idle. Also has enough vacuum for power booster on brakes. |
| All times are GMT -8. The time now is 05:45 AM. |
