-   -   Dexron VI Transmission fluid (https://www.racingjunk.com/forums/showthread.php?t=30881)
lanham 08-26-2011 07:00 PM
Can you use Dexron III transmission fluid when it calls for Dexron VI fluid? Are the fluids the same?
TopspeedLowet 08-27-2011 02:35 AM
NO
Bruce
john910 09-18-2011 02:06 PM
dextron v1 trans fluid
what about using vI for III ?
TopspeedLowet 09-19-2011 02:22 AM
What I have read in Gm's publications on transmission oil is that each newer number can be used for lower number fluids. Dextron 6 supersedes 5,4,and 3. You can use the recommended number fluid for the year or a higher number.
Bruce
