-   -   old gas???? (https://www.racingjunk.com/forums/showthread.php?t=30863)
bowhay 08-23-2011 09:19 AM
old gas????
will old fuel cause an engine to hydrolock repeatedly, because it will turn over then stop pull the plugs itl turn again and then stop once u put fuel to it
TheYellaBrick 08-23-2011 04:19 PM
It takes a LOT of liquid to hydrolock and engine. Maybe your timing is waaaay too far advanced ?
Any gasoline dumping out of the plug hole after you pull the plugs ?
You can bet your cookies that if you are getting THAT much fuel that it is contaminating the HECK out of your oil and washing down the cylinders and rings bigtime.
bowhay 08-24-2011 09:17 AM
ok il try retarding it and seeing what it does
