-   -   Engine Oils in a Drag Racing Application (https://www.racingjunk.com/forums/showthread.php?t=30835)
camman1967 08-16-2011 05:40 PM
I have a Big Block Ford that runs on Methanol. I have had bad luck with a lot of different oils......they break down quickly. After watching ESPN2 a few months back I seen Chris Demke (TAD) running a product called CleanBoost Performance Oil. I called this group and bought some of their 15w40 for my drag car.......since then, no engine failures and I can run 10 to 15 times down the 1/4 mile without draining the oil. This stuff really works.
Check them out at www.cleanboostoil.com
hammertime 08-16-2011 06:07 PM
10-15 runs on just a normal big block ford on alky ? I assume bracket racing ? or what ?
I've ran as far as 50 with alky carb and alky injection and looked like new when I've drained it. vr1 :)
TheRabbit 08-17-2011 04:58 PM
1st post and trying to sell something.
How many engine failures did you have per brand of oil.
Which was the worst oil? What was the "failure" that you had?
Were you using a Fram filter????????? That may have been you problem the whole time.
You should place adds in the Classified section.
curtisreed 08-17-2011 06:39 PM
Does this smell like spam to anyone else? 15 passes LOL. That's just a good two day race. I would throw stuff at someone that tried to drain my oil at 15 passes. :x
Curtis
tazracing 08-18-2011 03:55 AM
USE VR1 NOT STREET LEGAL 20/50 WORKS GOOD
wazup 08-18-2011 05:34 AM
Have used it for years with no problems.
To change oil every other race is crazy and a waste at the cost of the oil. I spend around 70.00 when i change out mine and thats around 50 passes or more depending on how it looks.
tazracing 08-18-2011 08:05 AM
I also use wix 51061R FILTER
itsabird 08-18-2011 09:11 AM
Curtis
Yep,
482 08-18-2011 01:03 PM
"I can run 10 to 15 times down the 1/4 mile without draining the oil. This stuff really works."
LOL
You would have to get at least semi-final money each week just to keep the oil changed :cry:
oldandtired 08-19-2011 10:42 AM
Yep.....
