-   -   IDLE ADJUSTMENT (https://www.racingjunk.com/forums/showthread.php?t=30813)
JEFF69Z28 08-10-2011 04:45 AM
IDLE ADJUSTMENT
How would adjust the idle on my carb with a adjust screw on the primaries and a screw on the secondary?If it is not adjust correctly would the affect the launch of my car?im footbraking.
markdunlap 08-11-2011 02:54 PM
idle
OK, since no one jumped in, I will try.
I am assuimimg Holley carb, but about the same for any carb really.
You turn each screw in and out until you get the highest vacuum reading or the highest rpm.
If the idle gets too high, just back off your main idle screw and continue.
I like to use a vac gage since I have a big one and it is easy to see changes.
If you can turn in the screws all the way and it makes no difference or is highest reading with screw all the way in, the idle curcuit is not working and is trying to ruin on the main curcuit.
The throttle blades could be too far open and the idle slot is too far exposed.
As far as idle being off affecting full throttle performance, it would have a minor effect at best.
Now maytbe someone will ad some good advise.
JEFF69Z28 08-13-2011 09:53 AM
I THINK I MIGHT HAVE SOLVED MY PROBLEM I PUT A 1050 ON MY CAR LAST NIGHT PICKED UP 2 MPH AND 2/10'S.NOW SHOULD I BUY A 2 CIRCUIT OR A 3 CIRCUIT 1050 I DRAG RACE THIS CAR ONLY THE BORROWED CARB WAS A 9357 1050.
hammertime 08-13-2011 11:44 AM
www.apdracing.com
pickup some more et ;)
