-   -   cam for bbc 622 ci (https://www.racingjunk.com/forums/showthread.php?t=30810)
samitun 08-09-2011 06:50 PM
cam for bbc 622 ci
need a cam for new engine,622 bbc,dart 355cnc heads,yea I know should be different head but that is what i have,14.5 comp,4.560 bore,4.75 stroke,dart tall deck dom. intake.called ohio crank and SSRE and they said in the 830,s on intake,800 on ex.114 lc,286/306 at .050.is this close?
TheRabbit 08-10-2011 10:23 AM
Need a lot more info.
What's it for?
How much does vehicle weigh?
How much NOS?
Flow rate of the heads?
How many RPM's do you expect to turn?
Is the rest of the motor built to handle that kind of RPM's?
What kind of trans and stall?
What does Ohio crank know about camshafts?
I'd rather call a cam manufacturer instead of a crank guy. JMO.
Just because a motor makes big hp on a dyno doesn't mean it's the best choice in your vehicle.
I had a 548 with a pretty big cam, but let the engine builder talk me into a bigger cam. It went from 799hp to 869hp on the dyno, but I lost a full .10 in 200' and never got it back with that cam.
Bigger is not always better!
topsportsman1 08-11-2011 08:01 PM
I may have what you need Jassie :P
