-   -   Powerglide pump (https://www.racingjunk.com/forums/showthread.php?t=30809)
TS1955 08-09-2011 12:51 PM
Powerglide pump
Once a powerglide pump has been made to accept a turbo spline input shaft, can a powerglide spline input shaft be put back into the pump?
TS1955
Robstclair 08-09-2011 02:41 PM
You can put the glide shaft right back in with no other changes. the diference is the busging that goes in the end of the stator shaft to support the turbo shaft. You can remove the bushing, but it is not nesecary because the glide shaft is smaller diamater and will not toutch the bushing.
Rob
TS1955 08-10-2011 05:13 AM
Rob
Thanks Rob. I was pretty sure about that but wanted to confirm it.
TS1955
