-   -   info on 861 casting bowtie heads for bbc (https://www.racingjunk.com/forums/showthread.php?t=30804)
cphip 08-08-2011 02:33 PM
I recently bought a bbc with a set of the 861 "snowflake" bowtie heads. The heads have been heavily worked and have epd racing heads and the number 1574 stamped on the end they also have the word russ and the numbers 12331 stamped under that. the intake manifold is also worked to match the heads it is a holley strip dominator that has been cut to pieces and welded back togther. I was wondering if anyone had any iinfo or knows where i can get info on these heads. The interenet has very limited info on epd and i know they are no longer in buisness. thinks for any help that you guys might be able to provide.
fla1976 08-08-2011 02:39 PM
Here is a number for them. Don't know if it is still good. EPD Racing Components 775-246-5015
cphip 08-08-2011 03:07 PM
Thank you very much for the reply. I will give the number a try.
