lean condition
Say if you were running a blown alcohol sbc what kind of EGT's and characteristics would you find this may sound stupid but I know you can run a motor lean so lean that it won't really make any power or hurt its self! Just having a little problem getting my car to really make any power
I like running my EGT around 1150 deg is your motor injected or carb.
Carb but the EGT's are only going up to 800 ish but the motor is wantn to run a little warm
800 on the egts is alot lean thats why its running warm
More details, you should be making some hp!
Dont have an EGT set up on my car but what would be a good reading on a single EGT in each header?
Well I have fattened it up a bunch and now have the biggest jets I own in my carbs and the motor is still running 185 degrees still seams to be a little to hot with alcohol to me. Motor was wantn to run over 200 be for. I have jumped the jets up a lot. But I think my EGT gauge isn't worth a crap it still reads the same and I've picked up over 1/2 second. I would think the actual EGT would have changed.
Is the motor idling high? Are you sure you did not suck an intake gasket?
| All times are GMT -8. The time now is 10:18 PM. |
