ford nine in.
Did a gear pack change with a complete oil drain, have put in three quarts and has not flowed out filler hole. Keep going or hold off???? Thanks for the reply
I know this sounds pretty basic but, is the rear axle housing LEVEL? If one side is lower, it'll fill up the entire housing tube on the low side.
everything I have says 2 to 2 1/2 quarts. Do you have a stock 9", are you filling in the stock hole or has someone welded a filler on the top?
ford 9.in
1976 ford 9 in. mosier center with4.56 bracket car. filler near top on side. Fluid is even w hole and will leave as is.
Wrong hole to check level.
| All times are GMT -8. The time now is 04:25 AM. |
