-   -   horsepower and 1/4 mile est (https://www.racingjunk.com/forums/showthread.php?t=30753)
hotrod1994 07-29-2011 11:35 AM
355 sbc 4 bolt main high nickel block
12:1 compression
afr eliminator aluminum heads 210cc intake runner 2.08 1.6 valves
65cc combustion chamber
comp extreme energy 294
@ .050 250 int./256 exh
Advertised Duration 294 int./306 exh.
valve lift with 1.5 ratio rocker arms 0.519 int./0.523 exh.
110 lsa
weiland team g intake
850 cfm carb
malory uni light distributor and hy fire 6 digital cd ignition
it will be in a 76 camaro around 3500 lbs
th350 3600 stall
28x10.5x15 m/t et drag slick on weld drag lights
3.73 gears
thanks guys
-logan
BEAST477 07-29-2011 05:55 PM
Still got too much carb. It might run mid 13's.
hotrod1994 07-29-2011 08:03 PM
ok so how big of a carb do you guys suggest
TS1955 07-30-2011 10:57 AM
Depending on the RPM range of your engine I would say somewhere around a 700 cfm carb. JMO
TS1955
Incognegro 07-30-2011 11:19 AM
I had a similar engine in my camaro actually less compression 10.5 and less cam and 64cc heads, with a 3800 stall in a powerglide and 456 in the rear car would go deadly consistent 12.09. Car weighed 3350, and the carb was a 4150 850cfm.
