-   -   V8 S-10 GETS HOT (https://www.racingjunk.com/forums/showthread.php?t=30658)
nan 07-04-2011 05:26 AM
V8 S-10 GETS HOT
I changed motors in my s10, old motor was an 350 oil drinker but never got hot. New motor is a used 1993 350 TBI changed to carb, same radiator etc. but had to use a smaller fan for clearence reasons to use the serpentine belt system. It runs fine but once it hits the 195 (thermostat) it keeps climbing untill the factory guage reads hot but it doesn't boil over and I have a temp gun and its 210 at the thermostat. It fills the overflow up every time. Could the plastic fan be too small? Head gasket?? Any one have this issue with a swap before? :shock:
ultimatewarrior1 07-04-2011 06:56 AM
Re: V8 S-10 GETS HOT
do you have room for dual fans in front of the radiator??might want try that should work for you.
kwkracing 07-05-2011 09:31 PM
tbi uses a reverse rotation fan and water pump.
nan 07-08-2011 03:15 PM
hot 350
It was the fan!!!!
