HP EST AND 1/4 MILE TIME EST
sbc 350 stock bottom end 10:1 compression with
aluminum angle plug heads ebay heads intake Port Volume 210cc Intake Valve Size 2.02 Exhaust Valve Size 1.60 lunati 60105 cam Advertised Duration : 284° /292° Duration @ .050 IN/EX : 241° /249° Gross Valve lift IN/EX .525''/.546'' LSA and ICL 110/106 RPM Range: 2500-6600 High Rise Aluminum Intake ebay intake single palne 2500 -7500 rpm rang holley 750 Mallory hy fire 6 and Mallory unilight distridutor with msd blaster coil th350 stage 2 shift kit 2200 stall 4:10 gears and 29x12.50 m/t sportsman pro |
mid 300's....carb is to big ....with that stall & carb you are not going to be happy
im gonna go with around 375hp and low 12's in the 1/4
hp ?
360 HP
I agree with the stall speed being too low, 3500 would be better, put a small NOS kit on this set up, they seem to wake up this combo. 750 carb have alot of range but it maybe a bit too big w/o spray JMO |
Re: HP EST AND 1/4 MILE TIME EST
its a stock body 76 camaro around 3500
| All times are GMT -8. The time now is 11:08 PM. |
