-   -   alky shut off cable (https://www.racingjunk.com/forums/showthread.php?t=30610)
dartsteve 06-23-2011 04:57 PM
alky shut off cable
I was hoping to get some advice on where to install shut off
In drivers compartment. 72 Dart door car.
Also what us better making a lever or using a t-handle.
Pics of yours would be great.
Also chute lever locations also.
bbchevy 06-23-2011 08:03 PM
Cable
My S/Off Cable is mounted to the Dash bar,just used a peice of Alu.and drilled a 3/8 hole for the Cable to go thru.Just make sure you can reach it when Belted in!
Chute Cable is just a Double C/Moly Bracket welded to the Upper Funny Car cage,w.a 8"Arm for the reales Cable.You can buy a Chute Cable w/Arm,and mt.it in thw center hole so it Pivots and hook Cable w/a clevis.
Hope that HELPS!
Later
G 8)
zipper06 06-23-2011 08:37 PM
My fuel shutoff is mounted to the top front halo bar, within easy reach, it's a simple mount looks a lot like a choke cable. I used to have a push pull PTO cable, mount one the down bar i hated it. The one i have you can just slap it and the fuel is off, much safer and quicker. I can post a pic. if you want to see the mounting.
oldandtired 06-24-2011 03:38 AM
Not trying to steal the post, but do you guys push or pull your chute handles? I pull but I like Zippers idea of slapping at it.
zipper06 06-24-2011 12:10 PM
Dave i don't have a chute on the Malibu (it's not fast enough) but on my other car with the Chute, i mounted a similar Alum. handle behind the shifter, useing a choke cable, and it was a simple matter to just push it forward to release the chute, no feeling for the loop ring or T'handle or reaching overhead, never failed.
dartsteve 06-24-2011 04:43 PM
i was sitting in the car today and was thinking about mounting the fuel shut off to the drivers door x brace it will be out of the way and easy to grab with left hand. still cant decide on t handle or lever. im leaning to the the chute on the right of shifter.
thanks for the input
