-   -   BRAKE LINES (https://www.racingjunk.com/forums/showthread.php?t=30596)
JEFF69Z28 06-22-2011 02:37 AM
BRAKE LINES
can you run braided line from the master cylinder or do they have to be steel?
oldandtired 06-22-2011 05:38 AM
Braded is OK, after all that's what you run to the front calipers.
wardy 07-14-2011 12:21 PM
Re: BRAKE LINES
I would use a hard line from the master cylinder, then braided line out to the caliper (from the frame). Too much braided line is a bad thing.......
fmfire672 03-04-2012 03:40 AM
Jeff Too much braided line will cause a spongy pedal. Stay with as much hard line as you can
TheYellaBrick 03-04-2012 07:35 AM
X2 Use the hardline as far as practical but use enough braided to ensure enough slack between frame and caliper to prevent strain and or tire/chassis rubbing.
olds48 03-04-2012 08:38 PM
Hard line is cheaper,lighter and longer lasting. The flexible parts are just necessary evils.
