-   -   NITROPHYL FLOATS (https://www.racingjunk.com/forums/showthread.php?t=30588)
JEFF69Z28 06-20-2011 08:09 AM
NITROPHYL FLOATS
WILL THEY ABSORB FUEL OVER TIME AND CAUSE PROBLEMS?
JUST WONDERING I CHANGED MY CAM THIS YEAR A LITTLE MORE LIFT SAME DURATION LSA IS 108 OLD WAS 111,CAR KINDA STUMBLES WHEN I LAUNCH IT(FOOTBRAKE)I TRIED BIGGER SHOOTER AND JETS,WENT DOWN IN JETS STILL DOES THE SAME THING,LAST YEAR I HAD NO PROLEMS,BUT I DID NOT DRAIN THE VP 110 OUT OF THE CARB OVER THE WINTER.TOOK IT APART BEFORE I FIRST RACE IT FUEL HAD EVAPORATED.I BLEW OUT THE CARB PASSAGES AND PUT ALL NEW GASKETS IN IT ALSO.
kbartley 06-22-2011 02:03 AM
Nitro Floats
How about the needleandseat o-rings?
Kris
JEFF69Z28 06-22-2011 02:44 AM
Re: Nitro Floats
Kris
never crossed my mind at the time i shall replace them and see what happens
curtisreed 06-22-2011 03:34 AM
Jeff, just to answer your original question. Yes those floats sometimes can get soaked with fuel. Take them out when they have been sitting in a full fuel bowl and weigh them comparing to the weight of a new one to see if they have gone bad. Unfortunately you have to buy a new one to get the weight in the first place unless you can borrow a new one.
Curtis
jmarksdragster 06-24-2011 06:46 AM
Float weights in grams
Plastic 10.7
Nitrophyl front 13.0
Nitrophyl double angle cut 9.5
Nitrophyl notched 10.8
Brass 15.0
jmarksdragster 06-24-2011 06:56 AM
Make sure you buy quality floats when using nitrophyl, there are some cheap ones out there that don't last. BLP is a great source for quality Holley parts.
